Datasheet Texas Instruments PCM1774RGPR — Даташит
Серия | PCM1774 |
Модель | PCM1774RGPR |
Маломощный стерео ЦАП с соотношением сигнал/шум 93 дБ и усилителем HP (S/W Control) 20-QFN от -40 до 85
16-Bit Low Power Stereo Audio DAC w/Analog Mixing Headphone Outputs datasheet
PDF, 1.9 Мб, Файл опубликован: 30 июл 2007
![]() 38 предложений от 17 поставщиков Интегральные микросхемы Микросхемы сбора данных - АЦП/ЦАП специального назначения | |||
PCM1774RGPR Texas Instruments | от 50 ₽ | ||
PCM1774RGPR, аудио ЦАП, 2 конвертера, 93дБ VQFN-20 | по запросу | ||
PCM1774RGPR Texas Instruments | по запросу | ||
Pin | 20 |
Package Type | RGP |
Industry STD Term | VQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | 1774 |
Width (мм) | 4 |
Length (мм) | 4 |
Thickness (мм) | .93 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Analog Outputs | 2 |
Архитектура | Delta-Sigma |
Control Interface | SPI,I2C |
DAC Channels | 2 |
DAC SNR(Typ) | 93 дБ |
Package Size: mm2:W x L | 20QFN: 16 mm2: 4 x 4(QFN) PKG |
Разрешение | 16 Bits |
Sampling Rate(Max) | 50 kHz |
- THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27PDF, 107 Кб, Файл опубликован: 27 сен 2000
The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727. - A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging FiltersPDF, 62 Кб, Файл опубликован: 27 сен 2000
In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1774 (4)
- PCM1774RGPR PCM1774RGPRG4 PCM1774RGPT PCM1774RGPTG4
- Semiconductors > Audio > Audio Converters > Audio DAC
