Datasheet Texas Instruments PCM1774RGPTG4 — Даташит
СерияPCM1774
МодельPCM1774RGPTG4
Маломощный стерео ЦАП с соотношением сигнал/шум 93 дБ и усилителем HP (S/W Control) 20-QFN от -40 до 85
16-Bit Low Power Stereo Audio DAC w/Analog Mixing Headphone Outputs datasheet
PDF, 1.9 Мб, Файл опубликован: 30 июл 2007
23 предложений от 12 поставщиков
Интегральные микросхемы Микросхемы сбора данных - АЦП/ЦАП специального назначения
Рутоника
PCM1774RGPTG4
178 ₽
Зенер
Россия и страны ТС
PCM1774RGPTG4
от 186 ₽
PCM1774RGPTG4
359 ₽
PCM1774RGPTG4
Pin20
Package TypeRGP
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Маркировка1774
Width (мм)4
Length (мм)4
Thickness (мм).93
Pitch (мм).5
Max Height (мм)1
Analog Outputs2
АрхитектураDelta-Sigma
Control InterfaceSPI,I2C
DAC Channels2
DAC SNR(Typ)93 дБ
Package Size: mm2:W x L20QFN: 16 mm2: 4 x 4(QFN) PKG
Разрешение16 Bits
Sampling Rate(Max)50 kHz
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1774 (4)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1774RGPTG4
