Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI PCM1780 — Даташит
СерияPCM1780
Datasheet Texas Instruments PCM1780
Стерео ЦАП с соотношением сигнал/шум 106 дБ (программное управление)
24-Bit, 192-kHz Sampling, Enhanced Multilevel, Delta-Sigma, Audio datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 5 июл 2006
PCM1780DBQPCM1780DBQG4PCM1780DBQR
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяДаДаНет
N123
Pin161616
Package TypeDBQDBQDBQ
Industry STD TermSSOPSSOPSSOP
Package QTY75752000
CarrierTUBETUBELARGE T&R
МаркировкаPCM1780PCM1780PCM1780
Width (мм)3.93.93.9
Length (мм)4.94.94.9
Thickness (мм)1.51.51.5
Pitch (мм).64.64.64
Max Height (мм)1.751.751.75
Parameters / ModelsPCM1780DBQ
PCM1780DBQ
PCM1780DBQG4
PCM1780DBQG4
PCM1780DBQR
PCM1780DBQR
Analog Outputs222
АрхитектураDelta-SigmaDelta-SigmaDelta-Sigma
Control InterfaceSPISPISPI
DAC Channels222
DAC SNR(Typ), дБ106106106
Package Size: mm2:W x L, PKG16SSOP: 19 mm2: 3.9 x 4.9(SSOP)16SSOP: 19 mm2: 3.9 x 4.9(SSOP)16SSOP: 19 mm2: 3.9 x 4.9(SSOP)
Разрешение, Bits242424
Sampling Rate(Max), kHz192192192
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1780 (3)
  • Semiconductors> Audio> Audio Converters> Audio DAC
На английском языке: Datasheet Texas Instruments PCM1780
Политика конфиденциальности
