Datasheet Texas Instruments PCM1793 — Даташит
СерияPCM1793
Стерео ЦАП с соотношением сигнал/шум 113 дБ (аппаратное управление)
PCM1793: 24-Bit 192kHz Sampling Advanced Segment Audio Stereo DAC datasheet
PDF, 448 Кб, Версия: A, Файл опубликован: 19 янв 2004
PCM1793DBPCM1793DBG4PCM1793DBR
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяДаДаНет
N123
Pin282828
Package TypeDBDBDB
Industry STD TermSSOPSSOPSSOP
Package QTY47472000
CarrierTUBETUBELARGE T&R
МаркировкаPCM1793PCM1793PCM1793
Width (мм)5.35.35.3
Length (мм)10.210.210.2
Thickness (мм)1.951.951.95
Pitch (мм).65.65.65
Max Height (мм)222
Parameters / ModelsPCM1793DB
PCM1793DB
PCM1793DBG4
PCM1793DBG4
PCM1793DBR
PCM1793DBR
Analog Outputs222
АрхитектураAdvanced SegmentAdvanced SegmentAdvanced Segment
Control InterfaceH/WH/WH/W
DAC Channels222
DAC SNR(Typ), дБ113113113
Package Size: mm2:W x L, PKG28SSOP: 80 mm2: 7.8 x 10.2(SSOP)28SSOP: 80 mm2: 7.8 x 10.2(SSOP)28SSOP: 80 mm2: 7.8 x 10.2(SSOP)
Разрешение, Bits242424
Sampling Rate(Max), kHz192192192
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1793 (3)
  • Semiconductors> Audio> Audio Converters> Audio DAC
На английском языке: Datasheet Texas Instruments PCM1793
