Datasheet Texas Instruments PCM1794ADB — Даташит
СерияPCM1794A
МодельPCM1794ADB
Стерео ЦАП высочайшего качества с соотношением сигнал/шум 132 дБ (аппаратное управление) 28-SSOP от -25 до 85
PCM1794A 24-Bit, 192-kHz Sampling, Advanced Segment, Audio Stereo Digital-to-Analog Converter datasheet
PDF, 989 Кб, Версия: B, Файл опубликован: 7 дек 2015
Pin2828
Package TypeDBDB
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY4747
CarrierTUBETUBE
МаркировкаPCM1794A
Width (мм)5.35.3
Length (мм)10.210.2
Thickness (мм)1.951.95
Pitch (мм).65.65
Max Height (мм)22
Analog Outputs2
АрхитектураAdvanced Segment
Control InterfaceH/W
DAC Channels2
DAC SNR(Typ)127 дБ
Package Size: mm2:W x L28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG
Разрешение24 Bits
Sampling Rate(Max)192 kHz
  • HiFi Audio Circuit Design
    PDF, 252 Кб, Файл опубликован: 23 авг 2017
    With the increase in personal electronic devices, HiFi audio is more popular than ever in many applications, such as smartphones, music players, home theaters, and even car infotainment. Many engineers and consumers devote themselves to the endless journey in HiFi audio. This document will help engineers understand, judge, design, and optimize a HiFi audio circuit.
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1794A (3)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1794ADB
