Datasheet Texas Instruments PCM1794A-Q1 — Даташит
СерияPCM1794A-Q1
132-дБ, 24-бит, 192-кГц расширенный сегментный аудио стерео цифро-аудио преобразователь
PCM1794A-Q1 24-Bit, 192-kHz Sampling, Advanced Segment, Audio Stereo Digital-to-Analog Converter datasheet
PDF, 989 Кб, Версия: A, Файл опубликован: 7 дек 2015
PCM1794AQDBRQ1
Статус продуктаВ производстве
PCM1794AQDBRQ1
N1
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY2000
МаркировкаPCM1794AQ
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
Parameters / ModelsPCM1794AQDBRQ1
PCM1794AQDBRQ1
Analog Outputs2
АрхитектураAdvanced Segment
Control InterfaceH/W
DAC Channels2
DAC SNR(Typ), дБ127
Package Size: mm2:W x L, PKG28SSOP: 80 mm2: 7.8 x 10.2(SSOP)
Разрешение, Bits24
Sampling Rate(Max), kHz192
PCM1794AQDBRQ1
  • Out-of-Band Noise and Filtering for PCM DAC
    PDF, 447 Кб, Файл опубликован: 20 май 2005
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1794A-Q1 (1)
  • Semiconductors> Audio> Audio Converters> Audio DAC
На английском языке: Datasheet Texas Instruments PCM1794A-Q1
