Datasheet Texas Instruments PCM1798 — Даташит
СерияPCM1798
Стерео ЦАП с соотношением сигнал/шум 123 дБ (аппаратное управление)
PCM1798 24-Bit, 192-kHz Sampling, Advanced Segment, Audio Stereo Digital-to-Analog Converter datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 13 мар 2015
PCM1798DBPCM1798DBG4PCM1798DBR
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяДаДаНет
N123
Pin282828
Package TypeDBDBDB
Industry STD TermSSOPSSOPSSOP
Package QTY47472000
CarrierTUBETUBELARGE T&R
МаркировкаPCM1798PCM1798PCM1798
Width (мм)5.35.35.3
Length (мм)10.210.210.2
Thickness (мм)1.951.951.95
Pitch (мм).65.65.65
Max Height (мм)222
Parameters / ModelsPCM1798DB
PCM1798DB
PCM1798DBG4
PCM1798DBG4
PCM1798DBR
PCM1798DBR
Analog Outputs222
АрхитектураAdvanced SegmentAdvanced SegmentAdvanced Segment
Control InterfaceH/WH/WH/W
DAC Channels222
DAC SNR(Typ), дБ123123123
Package Size: mm2:W x L, PKG28SSOP: 80 mm2: 7.8 x 10.2(SSOP)28SSOP: 80 mm2: 7.8 x 10.2(SSOP)28SSOP: 80 mm2: 7.8 x 10.2(SSOP)
Разрешение, Bits242424
Sampling Rate(Max), kHz192192192
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1798 (3)
  • Semiconductors> Audio> Audio Converters> Audio DAC
На английском языке: Datasheet Texas Instruments PCM1798
