Линейка продуктов KEEN SIDE
Datasheet Texas Instruments PCM1863DBTR — Даташит
СерияPCM1863
МодельPCM1863DBTR
2-канальный программно-управляемый аудио АЦП мощностью 110 дБ с универсальным интерфейсом 30-TSSOP от -40 до 125
PCM186x 110dB 2ch and 4ch Audio ADCs with Universal Front End datasheet
PDF, 6.0 Мб, Версия: C, Файл опубликован: 25 авг 2014
Pin30
Package TypeDBT
Industry STD TermTSSOP
Package QTY2000
МаркировкаPCM1863
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
ADC Channels2
ADC SNR(Typ)110 дБ
Additional FeaturesDC control monitoring,Digital Mic Support,Energysense Signal Detection,Low-latency IIR linear-phase FIR filters,Mixer,PLL
Analog Inputs8
Control InterfaceI2C
Digital Audio InterfaceL
Package Size: mm2:W x L30TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Sampling Rate(Max)192 kHz
  • Evaluation Modules & Boards: PCM1863EVM
    PCM1863 110dB 2-Ch Software-Controlled Audio ADC With Universal Front End Evaluation Module
  • Optimizing Signal Chain Noise on PCM186x Devices
    PDF, 213 Кб, Файл опубликован: 5 фев 2015
  • Sitara Linux ALSA DSP Microphone Array Voice Recognition
    PDF, 529 Кб, Файл опубликован: 30 июн 2017
    Voice recognition applications requiring a superior user experience typically use a number of digital signal processing algorithms to filter, clean, and enhance microphone sampled audio. Frequently these systems will employ multiple microphones where more sophisticated algorithms can be used. These systems can leverage a Texas Instruments Digital Signal Processor to offload the complex real-time c
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1863 (2)
  • Semiconductors > Audio > Audio Converters > Audio ADC
На английском языке: Datasheet Texas Instruments PCM1863DBTR
