Datasheet Texas Instruments PCM2705DBR — Даташит
СерияPCM2705
МодельPCM2705DBR
Стерео ЦАП USB2.0 FS с соотношением сигнал/шум 98 дБ, линейным выходом и выходом S/PDIF, шина/автономное питание (программное управление) 28-SSOP от -25 до 85
Stereo Audio DAC With USB Interface Single-Ended Headphone Output and S/PDIF Out datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 15 янв 2009
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY2000
МаркировкаPCM2705
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
  • Differences between PCM270x and PCM270xC
    PDF, 78 Кб, Файл опубликован: 16 авг 2011
    This document presents the major differences between the PCM270x and PCM270xC audio data converters.
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM2705 (4)
  • Semiconductors > Audio > Audio Converters > Audio USB Converter
На английском языке: Datasheet Texas Instruments PCM2705DBR
