Datasheet Texas Instruments PCM2707PJTRG4 — Даташит
СерияPCM2707
МодельPCM2707PJTRG4
Стерео ЦАП USB2.0 FS с соотношением шум 98 дБ, линейным выходом и выходом S/PDIF, шина/автономное питание (программное управление + I2S) 32-TQFP от -25 до 85
Stereo Audio DAC With USB Interface Single-Ended Headphone Output and S/PDIF Out datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 15 янв 2009
IC AUDIO 16BIT 48K 32TQFP. Audio 16 bit 48k SPI, USB 32-TQFP (7x7). Data Acquisition - ADCs/DACs - Special Purpose
PCM2707PJTRG4
577 ₽
PCM2707PJTRG4
PCM2707PJTRG4
PCM2707PJTRG4
Pin32
Package TypePJT
Industry STD TermTQFP
JEDEC CodeS-PQFP-N
Package QTY1000
МаркировкаPCM2707
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).8
Max Height (мм)1.2
Additional FeaturesS/PDIF Output,Headphone Output
Analog Outputs2
Control InterfaceHID,SPI
Package Size: mm2:W x L32TQFP: 81 mm2: 9 x 9(TQFP) PKG
Sampling Rate(Max)48 kHz
Supply Voltage(s)3.3,5 В
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM2707 (4)
  • Semiconductors > Audio > Audio Converters > Audio USB Converter
На английском языке: Datasheet Texas Instruments PCM2707PJTRG4
