Datasheet Texas Instruments PCM2900CDB — Даташит
СерияPCM2900C
МодельPCM2900CDB
Стереокодек USB1.1 с линейным выходом (HID-интерфейс) 28-SSOP от -25 до 85
Stereo Audio Codec w/USB Interface, Single-Ended Analog In/Out & S/PDIF datasheet
PDF, 1.2 Мб, Файл опубликован: 8 сен 2011
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY50
МаркировкаPCM2900C
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
ADC Channels2
Additional FeaturesN/A
Analog Inputs2
Analog Outputs2
Control InterfaceHID
DAC Channels2
Package Size: mm2:W x L28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG
Sampling Rate(Max)48 kHz
Supply Voltage(s)5 В
  • Evaluation Modules & Boards: PCM2900CEVM-U
    PCM2900C Evaluation Module
  • Key Differences Between the PCM290x and PCM290xC
    PDF, 104 Кб, Файл опубликован: 14 сен 2011
    This document presents the major differences between the PCM290xB and PCM290xC series audio data converters.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM2900C (2)
  • Semiconductors > Audio > Audio Converters > Audio USB Converter
На английском языке: Datasheet Texas Instruments PCM2900CDB
