Datasheet Texas Instruments PCM2901E/2K — Даташит
| Серия | PCM2901 |
| Модель | PCM2901E/2K |
Стереокодек USB1.1 с линейным выходом, автономное питание (интерфейс HID) 28-SSOP от 0 до 70
Stereo Audio CODEC w/USB Interface, Single-Ended Analog Input/Output & S/PDIF datasheet
PDF, 700 Кб, Версия: C, Файл опубликован: 19 ноя 2007
Купить PCM2901E/2K на РадиоЛоцман.Цены — от 178 до 1 296 ₽14 предложений от 14 поставщиков IC STEREO AUD CODEC W/USB 28SSOP. Stereo Audio Interface 16 b USB 28-SSOP. Interface - CODECs | |||
| PCM2901E/2K Texas Instruments | 456 ₽ | ||
| PCM2901E/2K Texas Instruments | 592 ₽ | ||
| PCM2901E/2K Texas Instruments | по запросу | ||
| Pin | 28 |
| Package Type | DB |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | PCM2901E |
| Width (мм) | 5.3 |
| Length (мм) | 10.2 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | .65 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| ADC Channels | 2 |
| Additional Features | N/A |
| Analog Inputs | 2 |
| Analog Outputs | 2 |
| Control Interface | HID |
| DAC Channels | 2 |
| Package Size: mm2:W x L | 28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG |
| Sampling Rate(Max) | 48 kHz |
| Supply Voltage(s) | 3.3 В |
- Solving Enumeration Errors in USB Audio DAC and CODEC DesignsPDF, 157 Кб, Файл опубликован: 30 окт 2009
TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture. - Key Differences Between the PCM290x and PCM290xCPDF, 104 Кб, Файл опубликован: 14 сен 2011
This document presents the major differences between the PCM290xB and PCM290xC series audio data converters.
Серия: PCM2901 (3)
- PCM2901E PCM2901E/2K PCM2901EG4
- Semiconductors > Audio > Audio Converters > Audio USB Converter
