Datasheet Texas Instruments PCM2902BDB — Даташит
СерияPCM2902B
МодельPCM2902BDB
Стерео аудиокодек с интерфейсом USB, несимметричным аналоговым входом/выходом S/PDIF 28-SSOP от -25 до 85
Stereo Audio Codec with USB Interface, Single Ended Analog In/Out and S/PDIF datasheet
PDF, 670 Кб, Файл опубликован: 17 дек 2008
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY50
МаркировкаPCM2902B
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
Рекомендуемая замена
ReplacementPCM2902CDB
Replacement CodeS
  • Key Differences Between the PCM290x and PCM290xC
    PDF, 104 Кб, Файл опубликован: 14 сен 2011
    This document presents the major differences between the PCM290xB and PCM290xC series audio data converters.
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM2902B (2)
  • Semiconductors > Audio > Audio Converters > Audio USB Converter
На английском языке: Datasheet Texas Instruments PCM2902BDB
