Datasheet Texas Instruments PCM2904DB — Даташит
СерияPCM2904
МодельPCM2904DB
Стереокодек USB1.1 с линейным выходом, питание по шине (интерфейс HID + ток USB 500 мА) 28-SSOP от -25 до 85
Stereo Audio CODEC with USB Interface, Single-Ended Analog Input/Output and S/PD datasheet
PDF, 478 Кб, Версия: C, Файл опубликован: 9 ноя 2007
38 предложений от 18 поставщиков
IC STEREO AUD CODEC W/USB 28SSOP. Stereo Audio Interface 16 b USB 28-SSOP. Interface - CODECs
Рутоника
PCM2904DB
556 ₽
Зенер
Россия и страны ТС
PCM2904DB
от 714 ₽
PCM2904DB
1 009 ₽
PCM2904DB
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY47
МаркировкаPCM2904
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
ADC Channels2
Additional Features500mA Max Power Configuration
Analog Inputs2
Analog Outputs2
Control InterfaceHID
DAC Channels2
Package Size: mm2:W x L28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG
Sampling Rate(Max)48 kHz
Supply Voltage(s)5 В
  • Key Differences Between the PCM290x and PCM290xC
    PDF, 104 Кб, Файл опубликован: 14 сен 2011
    This document presents the major differences between the PCM290xB and PCM290xC series audio data converters.
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM2904 (3)
  • Semiconductors > Audio > Audio Converters > Audio USB Converter
На английском языке: Datasheet Texas Instruments PCM2904DB
