Datasheet Texas Instruments PCM2906CDBR — Даташит
| Серия | PCM2906C |
| Модель | PCM2906CDBR |
Стерео USB-кодек с линейным выходом и S/PDIF, питание по шине 28-SSOP от -25 до 85
Stereo Audio Codec with USB Interface, Single-Ended Analog In/Out & S/PDIF datasheet
PDF, 296 Кб, Файл опубликован: 18 ноя 2011
Купить PCM2906CDBR на РадиоЛоцман.Цены — от 206 до 1 696 ₽36 предложений от 16 поставщиков IC STEREO AUD CODEC W/USB 28SSOP. Stereo Audio Interface 16 b USB 28-SSOP. Interface - CODECs | |||
| PCM2906CDBR Texas Instruments | 473 ₽ | ||
| PCM2906CDBR Texas Instruments | 886 ₽ | ||
| PCM2906CDBR Texas Instruments | по запросу | ||
| Pin | 28 |
| Package Type | DB |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | PCM2906C |
| Width (мм) | 5.3 |
| Length (мм) | 10.2 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | .65 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| ADC Channels | 2 |
| Additional Features | S/PDIF I/O,500mA Max Power Configuration |
| Analog Inputs | 2 |
| Analog Outputs | 2 |
| Control Interface | HID |
| DAC Channels | 2 |
| Package Size: mm2:W x L | 28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG |
| Sampling Rate(Max) | 48 kHz |
| Supply Voltage(s) | 5 В |
- Evaluation Modules & Boards: PCM2906CEVM-U
PCM2906C Evaluation Module
- Key Differences Between the PCM290x and PCM290xCPDF, 104 Кб, Файл опубликован: 14 сен 2011
This document presents the major differences between the PCM290xB and PCM290xC series audio data converters. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM2906C (2)
- PCM2906CDB PCM2906CDBR
- Semiconductors > Audio > Audio Converters > Audio USB Converter
