Datasheet Texas Instruments PCM3000EG4 — Даташит
| Серия | PCM3000 |
| Модель | PCM3000EG4 |
Стереокодек с линейным выходом (S/W Control) 28-SSOP
PCM3000, PCM3001: 18-Bit Stereo Audio Codec, Single-Ended Analog Input/Output datasheet
PDF, 620 Кб, Версия: A, Файл опубликован: 28 окт 2004
Купить PCM3000EG4 на РадиоЛоцман.Цены — от 204 до 632 ₽8 предложений от 8 поставщиков Кодек, Audio Codec 2ADC / 2DAC 18Bit 28Pin SSOP Tube | |||
| PCM3000EG4 Texas Instruments | 204 ₽ | ||
| PCM3000EG4 Texas Instruments | 632 ₽ | ||
| PCM3000EG4 Texas Instruments | по запросу | ||
| PCM3000EG4 | по запросу | ||
| Pin | 28 |
| Package Type | DB |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 47 |
| Carrier | TUBE |
| Маркировка | PCM3000E |
| Width (мм) | 5.3 |
| Length (мм) | 10.2 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | .65 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
- Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECsPDF, 291 Кб, Файл опубликован: 27 сен 2000
This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies. - Control Port And Reset Operation SoundPlus Audio Converters and CODECsPDF, 77 Кб, Файл опубликован: 27 сен 2000
This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM3000 (4)
- PCM3000E PCM3000E/2K PCM3000E/2KG4 PCM3000EG4
- Semiconductors > Audio > Audio Converters > Audio CODEC
