Линейка продуктов KEEN SIDE
Datasheet Texas Instruments PCM3000E/2K — Даташит
СерияPCM3000
МодельPCM3000E/2K
Стереокодек с линейным выходом (S/W Control) 28-SSOP
PCM3000, PCM3001: 18-Bit Stereo Audio Codec, Single-Ended Analog Input/Output datasheet
PDF, 620 Кб, Версия: A, Файл опубликован: 28 окт 2004
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY2000
МаркировкаPCM3000E
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM3000 (4)
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments PCM3000E/2K
