Datasheet Texas Instruments PCM3168APAPRG4 — Даташит
СерияPCM3168A
МодельPCM3168APAPRG4
24-битный многоканальный аудиокодек, 6 входов/8 выходов, частота дискретизации 96/192 кГц 64-HTQFP от -40 до 85
PCM3168A 24-Bit, 96-kHz/192-kHz, 6-In/8-Out Audio Codec With Differential Input/Output datasheet
PDF, 2.1 Мб, Версия: A, Файл опубликован: 7 янв 2016
Кодек, 24Bit Multi-channel Audio CODEC 6CH-in/8CH-out with 96/192kHz sampling rate 64-HTQFP -40℃ to 85℃
PCM3168APAPRG4
652 ₽
PCM3168APAPRG4
652 ₽
PCM3168APAPRG4
PCM3168APAPRG4
Pin64
Package TypePAP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаPCM3168A
Width (мм)10
Length (мм)10
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
ADC Channels6
ADC SNR(Typ)107 дБ
Analog Inputs6
Analog Outputs8
DAC Channels8
DAC SNR(Typ)112 дБ
Digital Audio InterfaceR,L,I2S,TDM,DSP
Package Size: mm2:W x L64HTQFP: 144 mm2: 12 x 12(HTQFP) PKG
Sampling Rate(Max)192 kHz
  • Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)
    PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
  • Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP Port
    PDF, 105 Кб, Файл опубликован: 8 июл 2009
    This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications
  • Out-of-Band Noise Measurement Issues for Audio Codecs
    PDF, 145 Кб, Файл опубликован: 6 дек 2006
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM3168A (3)
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments PCM3168APAPRG4
