Линейка продуктов KEEN SIDE
Datasheet Texas Instruments PCM4104PFBT — Даташит
СерияPCM4104
МодельPCM4104PFBT
4-канальный аудио ЦАП 118 дБ SNR 48-TQFP от -10 до 70
PCM4104: High-Performance, 24-Bit, 216kHz Sampling, Four-Channel Audio D/A Conv datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 15 дек 2004
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierSMALL T&R
МаркировкаPCM4104
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Analog Outputs4
АрхитектураDelta-Sigma
Control InterfaceSPI,H/W
DAC Channels4
DAC SNR(Typ)118 дБ
Package Size: mm2:W x L48TQFP: 81 mm2: 9 x 9(TQFP) PKG
Разрешение24 Bits
Sampling Rate(Max)192 kHz
  • Evaluation Modules & Boards: PCM4104EVM
    PCM4104 Evaluation Module (EVM)
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM4104 (4)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM4104PFBT
