Datasheet Texas Instruments PCM5100APW — Даташит
СерияPCM5100A
МодельPCM5100APW
2VRMS DirectPath™, стерео ЦАП аудио 100 дБ с 32-битным интерфейсом PCM 384 кГц 20-TSSOP от -25 до 85
PCM510xA 2.1 VRMS, 112/106/100 dB Audio Stereo DAC with PLL and 32-bit, 384 kHz PCM Interface datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 6 май 2015
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY70
МаркировкаPCM5100A
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Analog Outputs2
АрхитектураDelta Sigma with line driver
Control InterfaceH/W
DAC Channels2
DAC SNR(Typ)100 дБ
Разрешение32 Bits
Sampling Rate(Max)384 kHz
  • Evaluation Modules & Boards: PCM5102EVM-U
    PCM5102 Evaluation Module
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM5100A (2)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM5100APW
