Datasheet ТI PCM5100A-Q1 — Даташит
СерияPCM5100A-Q1
Datasheet Texas Instruments PCM5100A-Q1
Automotive Catalog 2VRMS DirectPathв„ў, 100dB Audio Stereo DAC with 32-bit, 384kHz PCM Interface
PCM510xA 2.1 VRMS, 112/106/100 dB Audio Stereo DAC with PLL and 32-bit, 384 kHz PCM Interface datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 6 май 2015
PCM5100AQPWRQ1
Статус продуктаВ производстве
PCM5100AQPWRQ1
N1
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаP5100AQ1
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Parameters / ModelsPCM5100AQPWRQ1
PCM5100AQPWRQ1
Analog Outputs2
АрхитектураDelta Sigma with line driver
Control InterfaceH/W
DAC Channels2
DAC SNR(Typ), дБ100
Package Size: mm2:W x L, PKG20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP)
Разрешение, Bits32
Sampling Rate(Max), kHz384
PCM5100AQPWRQ1
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM5100A-Q1 (1)
  • Semiconductors> Audio> Audio Converters> Audio DAC
На английском языке: Datasheet Texas Instruments PCM5100A-Q1
Публикации по теме
Политика конфиденциальности
