Datasheet Texas Instruments PCM5101APWR — Даташит
| Серия | PCM5101A |
| Модель | PCM5101APWR |
2VRMS DirectPath™, стерео ЦАП аудио 106 дБ с 32-битным интерфейсом PCM 384 кГц 20-TSSOP от -25 до 85
PCM510xA 2.1 VRMS, 112/106/100 dB Audio Stereo DAC with PLL and 32-bit, 384 kHz PCM Interface datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 6 май 2015
Купить PCM5101APWR на РадиоЛоцман.Цены — от 32 до 204 ₽26 предложений от 15 поставщиков Микросхема Преобразователь DA, 2VRMS DirectPathTM, 106dB Audio Stereo DAC with 32Bit, 384kHz PCM Interface 20-TSSOP -25 to 85 | |||
| PCM5101APWR Texas Instruments | от 32 ₽ | ||
| PCM5101APWR Texas Instruments | 84 ₽ | ||
| PCM5101APWR Texas Instruments | 138 ₽ | ||
| PCM5101APWR Texas Instruments | 180 ₽ | ||
| Pin | 20 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | PCM5101A |
| Width (мм) | 4.4 |
| Length (мм) | 6.5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Analog Outputs | 2 |
| Архитектура | Delta Sigma with line driver |
| Control Interface | H/W |
| DAC Channels | 2 |
| DAC SNR(Typ) | 106 дБ |
| Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
| Разрешение | 32 Bits |
| Sampling Rate(Max) | 384 kHz |
- A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging FiltersPDF, 62 Кб, Файл опубликован: 27 сен 2000
In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM5101A (2)
- PCM5101APW PCM5101APWR
- Semiconductors > Audio > Audio Converters > Audio DAC
