Datasheet Texas Instruments PCM5102APWR — Даташит
| Серия | PCM5102A |
| Модель | PCM5102APWR |
2VRMS DirectPath™, стерео ЦАП аудио 112 дБ с 32-битным интерфейсом PCM 384 кГц 20-TSSOP от -25 до 85
PCM510xA 2.1 VRMS, 112/106/100 dB Audio Stereo DAC with PLL and 32-bit, 384 kHz PCM Interface datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 6 май 2015
Купить PCM5102APWR на РадиоЛоцман.Цены — от 52 до 476 ₽57 предложений от 22 поставщиков Микросхема Преобразователь DA, TEXAS INSTRUMENTS PCM5102APWR Digital to Analogue Converter, 32Bit, 384KSPS, Serial, 3V to 3.6V, TSSOP, 20Pins | |||
| PCM5102APWR Texas Instruments | 72 ₽ | ||
| PCM5102APWR Texas Instruments | от 116 ₽ | ||
| PCM5102APWR Texas Instruments | от 156 ₽ | ||
| PCM5102APWR Texas Instruments | 405 ₽ | ||
| Pin | 20 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | PCM5102A |
| Width (мм) | 4.4 |
| Length (мм) | 6.5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Analog Outputs | 2 |
| Архитектура | Delta Sigma with line driver |
| Control Interface | H/W |
| DAC Channels | 2 |
| DAC SNR(Typ) | 112 дБ |
| Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
| Разрешение | 32 Bits |
| Sampling Rate(Max) | 384 kHz |
- Evaluation Modules & Boards: PCM5102EVM-U
PCM5102 Evaluation Module
- A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging FiltersPDF, 62 Кб, Файл опубликован: 27 сен 2000
In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM5102A (2)
- PCM5102APW PCM5102APWR
- Semiconductors > Audio > Audio Converters > Audio DAC
