Datasheet Texas Instruments PCM5102AQPWRQ1 — Даташит
СерияPCM5102A-Q1
МодельPCM5102AQPWRQ1
Каталог автомобилей 2VRMS DirectPath™, аудио-стерео ЦАП 112 дБ с 32-битным интерфейсом PCM 384 кГц 20-TSSOP от -40 до 125
PCM510xA 2.1 VRMS, 112/106/100 dB Audio Stereo DAC with PLL and 32-bit, 384 kHz PCM Interface datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 6 май 2015
31 предложений от 17 поставщиков
Микросхема Преобразователь DA, Automotive Catalog 2VRMS DirectPathTM, 112dB Audio Stereo DAC with 32Bit, 384kHz PCM Interface 20-TSSOP -40℃ to 125℃...
PCM5102AQPWRQ1
456 ₽
Xinhuo Future
PCM5102AQPWRQ1
510 ₽
PCM5102AQPWRQ1
PCM5102AQPWRQ1
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаP5102AQ1
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Analog Outputs2
АрхитектураDelta Sigma with line driver
Control InterfaceH/W
DAC Channels2
DAC SNR(Typ)112 дБ
Разрешение32 Bits
Sampling Rate(Max)384 kHz
  • Evaluation Modules & Boards: PCM5102EVM-U
    PCM5102 Evaluation Module
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM5102A-Q1 (1)
  • PCM5102AQPWRQ1
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM5102AQPWRQ1
Публикации по теме
