Datasheet Texas Instruments PCM5121PW — Даташит
СерияPCM5121
МодельPCM5121PW
2 В RMS DIRECTPATH 106 дБ Аудио Стерео ЦАП с интерфейсом PCM и фиксированной обработкой звука 28-TSSOP от -25 до 85
PCM512x 2-VRMS DirectPathв„ў, 112/106-dB Audio Stereo DAC With 32-bit, 384-kHz PCM Interface datasheet
PDF, 2.3 Мб, Версия: B, Файл опубликован: 13 янв 2016
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY50
МаркировкаPCM5121
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Analog Outputs2
АрхитектураDelta Sigma with line driver
Control InterfaceI2C,SPI,H/W
DAC Channels2
DAC SNR(Typ)106 дБ
Package Size: mm2:W x L28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) PKG
Разрешение32 Bits
Sampling Rate(Max)384 kHz
  • Evaluation Modules & Boards: PCM5122EVM-U
    PCM5122 Evaluation Module
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM5121 (2)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM5121PW
