Datasheet Texas Instruments PCM5121PWR — Даташит
| Серия | PCM5121 |
| Модель | PCM5121PWR |
2 В RMS DIRECTPATH 106 дБ Аудио Стерео ЦАП с интерфейсом PCM и фиксированной обработкой звука 28-TSSOP от -25 до 85
PCM512x 2-VRMS DirectPathв„ў, 112/106-dB Audio Stereo DAC With 32-bit, 384-kHz PCM Interface datasheet
PDF, 2.3 Мб, Версия: B, Файл опубликован: 13 янв 2016
Купить PCM5121PWR на РадиоЛоцман.Цены — от 37 до 500 ₽23 предложений от 14 поставщиков IC DAC 16/24/32BIT 384K 28TSSOP. DAC, Audio 16 b, 24 b, 32 bit 384k PCM 28-TSSOP. Data Acquisition - ADCs/DACs -... | |||
| PCM5121PWR Texas Instruments | от 37 ₽ | ||
| PCM5121PWR Texas Instruments | 67 ₽ | ||
| PCM5121PWR Texas Instruments | 168 ₽ | ||
| t.com/product/detail/store/7900793/pcm5121pwr | по запросу | ||
| Pin | 28 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | PCM5121 |
| Width (мм) | 4.4 |
| Length (мм) | 9.7 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Analog Outputs | 2 |
| Архитектура | Delta Sigma with line driver |
| Control Interface | I2C,SPI,H/W |
| DAC Channels | 2 |
| DAC SNR(Typ) | 106 дБ |
| Package Size: mm2:W x L | 28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) PKG |
| Разрешение | 32 Bits |
| Sampling Rate(Max) | 384 kHz |
- Evaluation Modules & Boards: PCM5122EVM-U
PCM5122 Evaluation Module
- A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging FiltersPDF, 62 Кб, Файл опубликован: 27 сен 2000
In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
- Semiconductors > Audio > Audio Converters > Audio DAC
