Линейка продуктов KEEN SIDE
Datasheet Texas Instruments PCM55HPG6 — Даташит
СерияPCM55
МодельPCM55HPG6
16-Bit Monolithic Digital-to-Analog Converter
PDF, 293 Кб, Файл опубликован: 27 сен 2000
Pin24
Package TypeDVK
Industry STD TermSOP
Width (мм)9
Length (мм)15.8
Max Height (мм)2.5
RoHSНе совместим
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM55 (2)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM55HPG6
