Datasheet Texas Instruments PGA411-Q1 — Даташит
| Серия | PGA411-Q1 |
Резольверно-цифровой преобразователь со встроенным усилителем возбудителя и источником питания
PGA411-Q1 Resolver Sensor Interface datasheet
PDF, 2.9 Мб, Версия: E, Файл опубликован: 1 авг 2017
Купить PGA411-Q1 на РадиоЛоцман.Цены — от 12 349 до 2 362 500 ₽8 предложений от 8 поставщиков EVAL BOARD FOR PGA411. PGA411-Q1 Resolver-to-Digital Interface Evaluation Board. Evaluation and Demonstration Boards and Kits | |||
| PGA411Q1EVM Texas Instruments | 12 349 ₽ | ||
| PGA411Q1EVM Texas Instruments | 957 809 ₽ | ||
| PGA411Q1EVM Texas Instruments | 2 362 500 ₽ | ||
| PGA411Q1EVM Texas Instruments | по запросу | ||
| PGA411QPAPRQ1 | |
| PGA411QPAPRQ1 | |
| N | 1 |
| Pin | 64 |
| Package Type | PAP |
| Industry STD Term | HTQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 1000 |
| Carrier | LARGE T&R |
| Маркировка | PGA411QPAPRQ1 |
| Width (мм) | 10 |
| Length (мм) | 10 |
| Thickness (мм) | 1 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Parameters / Models | PGA411QPAPRQ1![]() |
| Angular Acceleration 10/12 bits(Max), rad/sВІ | 200,000/50,000 |
| Angular Accuracy 10/12 bits, +/-arc min | 10.56/2.64 |
| Архитектура | Resolver-to-Digital Converter,Exciter Amplifier,Boost Power Supply,Analog Front End |
| Boost Voltage | 10 to 17 |
| Exciter Amplifier Current(Max), мА | 145 |
| Exciter Amplifier Frequency, kHz | 10 to 20 |
| Input Voltage(Max), В | 5 |
| Interface | Parallel,Encoder,SPI,Analog |
| Рабочий диапазон температур, C | от -40 до 125 |
| Package Group | HTQFP |
| Package Size: mm2:W x L, PKG | 64HTQFP: 144 mm2: 12 x 12(HTQFP) |
| Rating | Automotive |
| Разрешение, Bits | 12 |
| Sensor Supply Current(Max), мА | 145 |
| Settling Time at 180 degrees, ms | 1.5 |
| Special Features | SafeTI Semiconductor Component,Automatic and Manual Phase Correction,Sensor Input Fault Detection,Internal and External Oscillator,Analog & Logic Built-In Self-Test for Fault Detection |
| Topology | Boost |
| Tracking Rate 10/12 bits(Max), rpm | 200,000/72,000 |
| PGA411QPAPRQ1 | |
- Design considerations for resolver-to-digital converters in electric vehiclesPDF, 817 Кб, Файл опубликован: 26 янв 2016
- AFE Design Guide and Fault Diagnostics With PGA411-Q1PDF, 785 Кб, Файл опубликован: 11 ноя 2016
This report covers design calculations for the analog front-end (AFE) filter and discusses the fault diagnostics coverage and optimization for the AFE components for the PGA411-Q1 resolver sensor interface device. - Safety Manual for PGA411-Q1 Resolver Sensor InterfacePDF, 286 Кб, Файл опубликован: 11 фев 2016
This document is a safety manual for the Texas Instruments PGA411-Q1 resolver sensor interface. This manual provides information to help developers integrate the PGA411-Q1 device into safety related systems. - PGA411-Q1 PCB Design GuidelinesPDF, 1.5 Мб, Файл опубликован: 8 мар 2016
The PGA411-Q1 device is a resolver-to-digital converter, with an integrated exciter-amplifier, boost-converter power supply, that is capable of both exciting and reading the sine and cosine output from a resolver sensor.This document presents several guidelines for designing a PGA411-Q1 based PCB and includes recommendations for device placement and proper layout. - PGA411-Q1 Step-by-Step Initialization With Any Host SystemPDF, 289 Кб, Файл опубликован: 10 мар 2016
This application report includes the initialization sequence and code examples for the PGA411-Q1 device. This guide also describes how to interface with the PGA411-Q1 device.The sections in this document list the recommended sequence to communicate with the PGA411-Q1 device, the step-by-step configuration, and the code snippets for basic functionality for an in-depth discussion of codes. - Software Developer Guide for PGA411-Q1PDF, 201 Кб, Файл опубликован: 22 июл 2016
The objective of this guide is to explain high-level software flow for platform development with the PGA411-Q1 device.This report starts with a high-level overview of the software development flow, describing various functions and abstractions. Then, the report then describes three layers which are: the main program loop, the PGA411-Q1 specific functions, and the hardware abstraction - Troubleshooting Guide for PGA411-Q1PDF, 1.7 Мб, Файл опубликован: 1 фев 2016
Use this guide as the first step in troubleshooting any issues while using the PGA411-Q1 device. This guide includes example waveforms and information on faults that assist in the process to troubleshoot issues.
Серия: PGA411-Q1 (1)
- Semiconductors> Sensing Products> Resolver/Encoder Sensor Signal Conditioners
