Datasheet Texas Instruments PGA460TPWRQ1 — Даташит
СерияPGA460-Q1
МодельPGA460TPWRQ1
Автомобильный ультразвуковой сигнальный процессор и драйвер преобразователя 16-TSSOP от -40 до 105
PGA460-Q1 Automotive Ultrasonic Signal Processor and Transducer Driver datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 25 авг 2017
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаPGA460
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
# Input Channels1
Active Supply Current(Typ)12 мА
InterfaceUART / USART, TCI (Time Command Interface), OWU (One-Wire UART)
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
RatingAutomotive
Sleep Supply Current(Typ)300 uA
Special FeaturesFully integrated
Напряжение питания6 Max
  • Evaluation Modules & Boards: BOOSTXL-PGA460
    PGA460-Q1 Ultrasonic Sensor Signal Conditioning EVM With Transducers
  • PGA460-Q1 in Ultrasonic Park Assist (UPA)
    PDF, 270 Кб, Файл опубликован: 19 июл 2017
  • PGA460-Q1 in Automotive Ultrasonic Kick-to-open Liftgate Systems (Rev. A)
    PDF, 211 Кб, Версия: A, Файл опубликован: 19 сен 2017
  • PGA460 Frequently Asked Questions (FAQ) and EVM Troubleshooting Guide
    PDF, 2.0 Мб, Файл опубликован: 1 май 2017
    This document is intended to answer the most common and frequently asked questions (FAQs) that users have when evaluating the PGA460 or PGA460-Q1 EVM and GUI. Step-by-step procedures to hardware troubleshooting and software debugging are provided. Recommendations to improve performance and best practices to prevent device failure, GUI errors, or improper measurement techniques are also discussed.
  • PGA460 Software Development Guide (Rev. A)
    PDF, 269 Кб, Версия: A, Файл опубликован: 22 авг 2017
    The objective of this guide is to explain the high-level software flow for platform development with the PGA460 device using UART, Time Command Interface (TCI), and/or One-Wire UART (OWU) communication.This report contains a software development flow-chart, one-time mass-production initializationrequirements, main executable routines, and source code examples. The example softw
  • PGA460 Ultrasonic Module Hardware and Software Optimization
    PDF, 340 Кб, Файл опубликован: 17 фев 2017
    This document introduces all of the necessary design and environmental considerations when developing and optimizing an ultrasonic sensor module using the PGA460. Ultrasonic modules behave differently across various temperatures, transmission mediums, targets, and transducers types. Building the module, therefore, requires an understanding of the different ultrasonic components available for pairi
Серия: PGA460-Q1 (2)
  • Semiconductors > Sensing Products > Ultrasonic Sensing
На английском языке: Datasheet Texas Instruments PGA460TPWRQ1
