Datasheet Texas Instruments PT3105 — Даташит
СерияPT3105
Изолированный преобразователь постоянного тока в постоянный, 12 В, 15 Вт, 24 В, вход
15 Watt, 24V to 5V/12V/15V Isolated DC-DC Converter
PDF, 186 Кб, Файл опубликован: 15 май 1998
PT3105C
Статус продуктаНе рекомендуется для новых разработок
PT3105C
N1
Pin6
Package TypeEGE
Industry STD TermDIP MODULE
JEDEC CodeR-PDIP-G
Width (мм)37.3
Length (мм)42.2
Thickness (мм)8.15
Pitch (мм)2.54
Max Height (мм)8.55
PT3105C
RoHSНе совместим
  • Hot Plug-In In-Rush Current Limiting Circuits for PT3100/4100/3320 DC-DC Convert (Rev. A)
    PDF, 52 Кб, Версия: A, Файл опубликован: 3 авг 2000
  • Using the PT3100/4100 Series 15-Watt Isolated DC-DC Converter
    PDF, 106 Кб, Файл опубликован: 15 май 1998
    Discusses the general features of the PT3100/4100 series DC-DC converters, such as over-current protection, over-current protection, over-temperature protection, and Remote On/Off control. The note also details the input source and PCB layout recommendations.
  • Adding Undervoltage Lockouts to the PT3100/4100 Series
    PDF, 108 Кб, Файл опубликован: 15 май 1998
    Provides details on a low-cost input under-voltage lockout feature may be added to the PT3100/4100 product series.
  • Reliability Prediction for PT3100/4100 Isolated DC-DC Converters
    PDF, 148 Кб, Файл опубликован: 15 май 1998
    Provides curves for the predicted MTBF vs the ambient operating temperature for the PT3100/4100 isolated products. The note also includes a discussion on the reliability cal-culation methods, the physical construction, and a block diagram of the product.
  • PT3100/4100 Series Thermal Considerations
    PDF, 109 Кб, Файл опубликован: 15 май 1998
    Gives the recommended PCB layout for the PT3100/4100 series DC-DC converters and gives guidance on the expected thermal resistance and temperature rise Vs power dissi-pation.
  • Reflow Soldering Requirements for Plug-In Power Suface-Mount Products
    PDF, 44 Кб, Файл опубликован: 1 авг 2000
    Describes the soldering requirements for the surface mount versions of all Plug-in Power products, and gives guidelines for the development of a suitable reflow profile.
  • ISR Input/Output Filters (Rev. A)
    PDF, 81 Кб, Версия: A, Файл опубликован: 3 авг 2000
  • EMI Considerations for DC to DC Converters and Integrated Switching Regulators (Rev. A)
    PDF, 38 Кб, Версия: A, Файл опубликован: 3 авг 2000
  • ISR Qualification Process (Rev. A)
    PDF, 50 Кб, Версия: A, Файл опубликован: 3 авг 2000
Серия: PT3105 (1)
  • Semiconductors> Power Management> Power Modules> Isolated Module> Standard Brick Module
На английском языке: Datasheet Texas Instruments PT3105
