Datasheet Texas Instruments RCV420JPG4 — Даташит
СерияRCV420
МодельRCV420JPG4
Прецизионный приемник токовой петли от 4 мА до 20 мА 16-PDIP 0–70
Precision 4mA to 20mA Current Loop Receiver datasheet
PDF, 207 Кб, Файл опубликован: 27 сен 2000
IC OPAMP GP 1 CIRCUIT 16DIP. General Purpose Amplifier 1 Circuit 16-PDIP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
RCV420JPG4
355 ₽
RCV420JPG4
782 ₽
RCV420JPG4
979 ₽
RCV420JPG4
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаRCV420JP
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Full Scale Input Range4 to 20mA
Package GroupPDIP
Sub-Family4-20mA Transmitter
Vs(Max)36 В
Vs(Min)11.4 В
  • Evaluation Modules & Boards: DLPNIRSCANEVM
    DLPВ® NIRscanВ™ Evaluation Module
  • 0 To 20 mA Receiver Using RCV42
    PDF, 26 Кб, Файл опубликован: 27 сен 2000
    Many industrial current-loop applications call for conversion of a 0 to 20mA input current into 0 to 5V output. The RCV420 is intended primarily as a complete solution for precise 4 to 20mA to 0 to 5V conversion. But, with the addition of one or two external 1% resistors, the RCV420 can also accurately convert a 0 to 20mA input into a 0 to 5V output.
  • Input Overload Protection for the RCV420 4-20mA Current-Loop Receiver
    PDF, 31 Кб, Файл опубликован: 27 сен 2000
    Because of its immunity to noise, voltage drops, and line resistance the 4?20mA current loop has become the standard for analog signal transmission in the process control industry. The RCV420 is the first one-chip solution for converting a 4?20mA signal into a precision 0?5V output. Although the on-chip current sensing resistor is designed to tolerate moderate overloads, it can be damaged by large
  • Isolation Amps Hike Accuracy and Reliability
    PDF, 94 Кб, Файл опубликован: 2 окт 2000
    Fault tolerance, transient protection, and interference rejection are valuable features that isolation amplifiers bring to critical circuitry. Two useful examples of how designers can employ isolation amplifiers to improve their systems? performance and reliability are process temperature controllers and electrocardiogram (ECG) amplifiers.
  • Implementing a 4 mA to 20 mA Current Loop on TI DSPs
    PDF, 204 Кб, Файл опубликован: 5 янв 2004
    Use of 4-mA to 20-mA (4-20 mA) current loops has become the standard in the process-control industry due to their increased resistance to noise compared to voltage-modulated signals. TI digital signal processors (DSPs) increasingly are becoming the standard for microcontrollers in a control application. Therefore, an opportunity exists to connect the many sensors and electromechanical devices on t
  • Single Supply 4-20mA Current Loop Receiver
    PDF, 29 Кб, Файл опубликован: 27 сен 2000
    Many industrial current-loop data acquisition systems operate on a 24V or 28V single supply. You can make a single-supply current loop receiver with the RCV420 by using its 10V reference as a pseudo ground. The RCV420 will convert a 4-20mA loop current into a 0 to 5V output voltage with no external components required. The current loop can be sourcing or sinking and can be referenced to either the
  • IC Building Blocks Form Complete Isolated 4-20mA Current-Loop
    PDF, 72 Кб, Файл опубликован: 27 сен 2000
    Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Adding isolation to the 4-20mA current loop protects system electronics from electrical noise and transients. It also allows transducers to be electrically separated by hundreds of volts.
  • 20mA to 0-20mA Converter & Current Summing Current-to-Current Converters
    PDF, 57 Кб, Файл опубликован: 2 окт 2000
    Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Burr-Brown offers a complete line of monolithic 4mA to 20mA current loop transmitters and receivers.
  • Implementation and Applications of Current Sources and Current Receivers
    PDF, 427 Кб, Файл опубликован: 27 сен 2000
    This application guide is intended as a source book for the design and application of: Current sourcesCurrent sinksFloating current sourcesVoltage-to-current converters(transconductance amplifiers)Current-to-current converters (current mirrors)Current-to-voltage converters(transimpedance amplifiers)
Серия: RCV420 (4)
  • Semiconductors > Sensing Products > Application-Specific Sensor Signal Conditioners
На английском языке: Datasheet Texas Instruments RCV420JPG4
