Datasheet Texas Instruments SCAN921023SLC/NOPB — Даташит
СерияSCAN921023
МодельSCAN921023SLC/NOPB
10-битный сериализатор 20–66 МГц с тестовым доступом IEEE 1149.1 49-NFBGA от -40 до 85
20-66MHz 10Bit Bus LVDS Serial & Deserial w/IEEE 1149.1 (JTAG) & at-speed BIST datasheet
PDF, 938 Кб, Версия: D, Файл опубликован: 15 апр 2013
IC SERIALIZER 10BIT 49FBGA. 660Mbps Serializer 10 Input 1 Output 49-BGA (7x7). Interface - Serializers, Deserializers
SCAN921023SLC/NOPB
367 ₽
Hi-Tech Circuit Group
SCAN921023SLC/NOPB
SCAN921023SLC/NOPB
SUV System
SCAN921023SLC/NOPB
Pin4949
Package TypeNZANZA
Industry STD TermNFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-N
Package QTY416416
МаркировкаSLCSCAN921023
Width (мм)77
Length (мм)77
Thickness (мм)1.41.4
Pitch (мм).8.8
Max Height (мм)1.51.5
Approx. Price (US$)4.80 | 1ku
Clock Max(MHz)66
Clock Min(MHz)20
CommunicationsYes
Compression Ratio10 to 1
Data Throughput(Mb/s)660
ESD(kV)2
FunctionSerializer
ICC(Max)(mA)130
Input CompatibilityLVTTL
JTAG1149.1Yes
No. of Tx1
Operating Temperature Range(C)-40 to 85
Output CompatibilityLVDS
BLVDS
PLL Frequency(MHz)20-66
Package GroupNFBGA
Package Size: mm2:W x L (PKG)49NFBGA: 49 mm2: 7 x 7(NFBGA)
Parallel Bus Width10
Parallel Bus Width(bits)10
Payload/Channel(Mbps)660
Power Consumption(mW)248
Sensing & ImagingYes
Start/Stop BitYes
Supply Voltage(s)(V)3.3
SupplyVoltage(Volt)3.3
Total Throughput(Mbps)660
  • DS15BA101 & DS15EA101 Enable Long Reach Applications for Embedded Clock SER/DES (Rev. E)
    PDF, 170 Кб, Версия: E, Файл опубликован: 29 апр 2013
    Reduction in system size, increase in system performance and savings in system cost are valuablebenefits that SER/DES devices (Serializers and Deserializers) bring to many system designers. Thesebenefits are the reason why SER/DES are integral pieces of many of today’s high-speed systems.One of the design constraints for these systems is the maximum transmission distance between a serializer
Серия: SCAN921023 (2)
  • Semiconductors > Interface > Serializer, Deserializer > BLVDS/LVDS SerDes (<100 MHz)
На английском языке: Datasheet Texas Instruments SCAN921023SLC/NOPB
