Datasheet Texas Instruments SNJ54ABT16373AWD — Даташит
Серия | SN54ABT16373A |
Модель | SNJ54ABT16373AWD |
16-битные прозрачные защелки D-типа с выходами с 3 состояниями 48-CFP от -55 до 125
16-Bit Transparent D-Type Latches With 3-State Outputs datasheet
PDF, 747 Кб, Версия: C, Файл опубликован: 1 май 1997
Pin | 48 | 48 | 48 | 48 |
Package Type | WD | WD | WD | WD |
Industry STD Term | CFP | CFP | CFP | CFP |
JEDEC Code | R-GDFP-F | R-GDFP-F | R-GDFP-F | R-GDFP-F |
Package QTY | 1 | 1 | 1 | 1 |
Carrier | TUBE | TUBE | TUBE | TUBE |
Маркировка | WD | SNJ54ABT16373A | 5962-9320001QX | A |
Width (мм) | 9.66 | 9.66 | 9.66 | 9.66 |
Length (мм) | 15.88 | 15.88 | 15.88 | 15.88 |
Thickness (мм) | 2.48 | 2.48 | 2.48 | 2.48 |
Pitch (мм) | .635 | .635 | .635 | .635 |
Max Height (мм) | 3.05 | 3.05 | 3.05 | 3.05 |
Mechanical Data | Скачать | Скачать | Скачать | Скачать |
3-State Output | Yes |
Bits | 16 |
F @ Nom Voltage(Max) | 150 Mhz |
ICC @ Nom Voltage(Max) | 89 мА |
Тип входа | TTL |
Output Drive (IOL/IOH)(Max) | 64/-32 мА |
Тип выхода | TTL |
Package Group | CFP |
Package Size: mm2:W x L | See datasheet (CFP) PKG |
Rating | Military |
Technology Family | ABT |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
tpd @ Nom Voltage(Max) | 6.3 нс |
RoHS | See ti.com |
- Quad Flatpack No-Lead Logic Packages (Rev. D)PDF, 1.0 Мб, Версия: D, Файл опубликован: 16 фев 2004
Texas Instruments (TI) Quad Flatpack No-lead (QFN) 14/16/20-terminal Pb-free plastic packages meet dimensions specified in JEDEC standard MO-241 allow for board miniaturization and hold several advantages over traditional SOIC SSOP TSSOP and TVSOP packages. The packages are physically smaller have a smaller routing area improved thermal performance and improved electrical parasitics while - Advanced BiCMOS Technology (ABT) Logic Characterization Information (Rev. B)PDF, 528 Кб, Версия: B, Файл опубликован: 1 июн 1997
The purpose of this document is to assist the designers of high-performance digital logic systems in using the advanced BiCMOS technology (ABT) logic family. Detailed electrical characteristics of these bus-interface devices are provided and tables and graphs have been included to compare specific parameters of the ABT family with those of other logic families. In addition typical data is provide - Advanced BiCMOS Technology (ABT) Logic Enables Optimal System Design (Rev. A)PDF, 115 Кб, Версия: A, Файл опубликован: 1 мар 1997
Advanced bus-interface logic (ABIL) products processed in submicron advanced BiCMOS technologies (ABT) address the specific end-equipment demands of workstations personal and portable computers and telecommunications markets. This document discusses ABIL as system bus interfaces the merits of ABT its I/O structure packaging and ABT products for end-equipment specific solutions. - Family of Curves Demonstrating Output Skews for Advanced BiCMOS Devices (Rev. A)PDF, 80 Кб, Версия: A, Файл опубликован: 1 дек 1996
This document shows the output skew for the ABT16254 ABT16952 and ABT16500A devices of the TI advanced BiCMOS (ABT) family. The data samples show which output skew is being examined where the data originates and how it is analyzed. Some errors present in the data are discussed. Skew curves at varying temperatures are given for the ABT16240 ABT16245 ABT16952 ABT16500A and ABT16249 devic
Серия: SN54ABT16373A (2)
- 5962-9320001QXA SNJ54ABT16373AWD
- Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
