Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SNJ54AHC573FK — Даташит
СерияSN54AHC573
МодельSNJ54AHC573FK
Восьмеричные прозрачные защелки типа D с выходами с 3 состояниями 20-LCCC от -55 до 125
SNx4AHC573 Octal Transparent D-Type Latches With 3-State Outputs datasheet
PDF, 2.2 Мб, Версия: L, Файл опубликован: 15 ноя 2013
Pin20202020
Package TypeFKFKFKFK
Industry STD TermLCCCLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY1111
CarrierTUBETUBETUBETUBE
Маркировка9685601Q2A5962-SNJ54AHC573FK
Width (мм)8.898.898.898.89
Length (мм)8.898.898.898.89
Thickness (мм)1.831.831.831.83
Pitch (мм)1.271.271.271.27
Max Height (мм)2.032.032.032.03
3-State OutputYes
Bits8
F @ Nom Voltage(Max)110 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Тип входаCMOS
Output Drive (IOL/IOH)(Max)50/-50 мА
Тип выходаCMOS
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Technology FamilyAHC
VCC(Max)5.5 В
VCC(Min)2 В
tpd @ Nom Voltage(Max)17.5,10 нс
RoHSSee ti.com
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments SNJ54AHC573FK
