Линейка продуктов KEEN SIDE
Datasheet Texas Instruments 5962-9686001Q2A — Даташит
СерияSN54AHC74
Модель5962-9686001Q2A
Двойные триггеры D-типа с положительным фронтом и четким и предустановленным 20-LCCC от -55 до 125
SN54AHC74, SN74AHC74 datasheet
PDF, 1.9 Мб, Версия: K, Файл опубликован: 2 дек 2013
Pin20202020
Package TypeFKFKFKFK
Industry STD TermLCCCLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY1111
CarrierTUBETUBETUBETUBE
Маркировка74FK9686001Q2A5962-SNJ54AHC
Width (мм)8.898.898.898.89
Length (мм)8.898.898.898.89
Thickness (мм)1.831.831.831.83
Pitch (мм)1.271.271.271.27
Max Height (мм)2.032.032.032.03
3-State OutputNo
Bits2
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.02 мА
Тип входаCMOS
Output Drive (IOL/IOH)(Max)50/-50 мА
Тип выходаCMOS
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Technology FamilyAHC
VCC(Max)5.5 В
VCC(Min)2 В
tpd @ Nom Voltage(Max)17.5,10.5 нс
RoHSSee ti.com
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Live Insertion
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Introduction to Logic
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
59629686001Q2A, 5962 9686001Q2A
На английском языке: Datasheet Texas Instruments 5962-9686001Q2A
