Datasheet Texas Instruments 5962-9686501Q2A — Даташит
СерияSN54AHCT374
Модель5962-9686501Q2A
Восьмеричные триггеры D-типа с фронтальным запуском и выходами с 3 состояниями 20-LCCC от -55 до 125
SN54AHCT374, SN74AHCT374 datasheet
PDF, 1.3 Мб, Версия: L, Файл опубликован: 9 июл 2003
Pin20202020
Package TypeFKFKFKFK
Industry STD TermLCCCLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY1111
CarrierTUBETUBETUBETUBE
Маркировка374FK9686501Q2ASNJ54AHCT5962-
Width (мм)8.898.898.898.89
Length (мм)8.898.898.898.89
Thickness (мм)1.831.831.831.83
Pitch (мм)1.271.271.271.27
Max Height (мм)2.032.032.032.03
3-State OutputYes
Bits8
F @ Nom Voltage(Max)70 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)8/-8 мА
Тип выходаCMOS
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Technology FamilyAHCT
VCC(Max)5.5 В
VCC(Min)4.5 В
tpd @ Nom Voltage(Max)11.5 нс
RoHSSee ti.com
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Live Insertion
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Introduction to Logic
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
59629686501Q2A, 5962 9686501Q2A
На английском языке: Datasheet Texas Instruments 5962-9686501Q2A
