Datasheet Texas Instruments 8301901FA — Даташит
| Серия | SN54ALS174 |
| Модель | 8301901FA |
Шестигранные шлепанцы типа D с прозрачным 16-CFP от -55 до 125
Hex/Quadruple D-Type Flip-Flops With Clear datasheet
PDF, 848 Кб, Версия: E, Файл опубликован: 23 май 2002
Hex D-type Flip-Flops With Clear 16-CFP -55 to 125 | |||
| 8301901FA Texas Instruments | по запросу | ||
| Pin | 16 | 16 |
| Package Type | W | W |
| Industry STD Term | CFP | CFP |
| JEDEC Code | R-GDFP-F | R-GDFP-F |
| Package QTY | 1 | 1 |
| Carrier | TUBE | TUBE |
| Маркировка | SNJ54ALS174W | 8301901FA |
| Width (мм) | 6.73 | 6.73 |
| Length (мм) | 10.3 | 10.3 |
| Thickness (мм) | 1.65 | 1.65 |
| Pitch (мм) | 1.27 | 1.27 |
| Max Height (мм) | 2.03 | 2.03 |
| 3-State Output | No |
| Bits | 6 |
| F @ Nom Voltage(Max) | 75 Mhz |
| ICC @ Nom Voltage(Max) | 19 мА |
| Тип входа | TTL |
| Рабочий диапазон температур | от -55 до 125 C |
| Output Drive (IOL/IOH)(Max) | 8/-0.4 мА |
| Тип выхода | TTL |
| Package Group | CFP |
| Package Size: mm2:W x L | See datasheet (CFP) PKG |
| Rating | Military |
| Technology Family | ALS |
| VCC(Max) | 5.5 В |
| VCC(Min) | 4.5 В |
| tpd @ Nom Voltage(Max) | 17 нс |
| RoHS | See ti.com |
- Bus-Interface Devices With Output-Damping Resistors Or Reduced-Drive Outputs (Rev. A)PDF, 105 Кб, Версия: A, Файл опубликован: 1 авг 1997
The spectrum of bus-interface devices with damping resistors or balanced/light output drive currently offered by various logic vendors is confusing at best. Inconsistencies in naming conventions and methods used for implementation make it difficult to identify the best solution for a given application. This report attempts to clarify the issue by looking at several vendors? approaches and discussi - Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
This document introduces the advanced Schottky family of clamped TTL integrated circuits (ICs). Detailed electrical characteristics of the 'AS and 'ALS devices with table formats are provided. Guidelines for designing high-performance digital systems using the Advanced Schottky family are given along with a brief summary of the solutions to most design decisions needed to implement systems using t - Live InsertionPDF, 150 Кб, Файл опубликован: 1 окт 1996
Many applications require the ability to exchange modules in electronic systems without removing the supply voltage from the module (live insertion). For example an electronic telephone exchange must always remain operational even during module maintenance and repair. To avoid damaging components additional circuitry modifications are necessary. This document describes in detail the phenomena tha - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
- Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Серия: SN54ALS174 (11)
- Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
