Datasheet Texas Instruments M38510/37201B2A — Даташит
| Серия | SN54ALS174 |
| Модель | M38510/37201B2A |
Шестигранные шлепанцы типа D с прозрачным 20-LCCC от -55 до 125
Hex/Quadruple D-Type Flip-Flops With Clear datasheet
PDF, 848 Кб, Версия: E, Файл опубликован: 23 май 2002
Купить M38510/37201B2A на РадиоЛоцман.Цены — от 3 131 до 3 870 ₽Микросхема Логический чип, Flip Flop D-Type Bus Interface Pos-Edge 1Element 20Pin CLLCC Tube | |||
| M38510/37201B2A Texas Instruments | 3 131 ₽ | ||
| M38510/37201B2A Texas Instruments | 3 870 ₽ | ||
| M38510/37201B2A Texas Instruments | по запросу | ||
| Pin | 20 | 20 |
| Package Type | FK | FK |
| Industry STD Term | LCCC | LCCC |
| JEDEC Code | S-CQCC-N | S-CQCC-N |
| Package QTY | 1 | 1 |
| Carrier | TUBE | TUBE |
| Маркировка | JM38510/ | 37201B2A |
| Width (мм) | 8.89 | 8.89 |
| Length (мм) | 8.89 | 8.89 |
| Thickness (мм) | 1.83 | 1.83 |
| Pitch (мм) | 1.27 | 1.27 |
| Max Height (мм) | 2.03 | 2.03 |
| 3-State Output | No |
| Bits | 6 |
| F @ Nom Voltage(Max) | 75 Mhz |
| ICC @ Nom Voltage(Max) | 19 мА |
| Тип входа | TTL |
| Рабочий диапазон температур | от -55 до 125 C |
| Output Drive (IOL/IOH)(Max) | 8/-0.4 мА |
| Тип выхода | TTL |
| Package Group | LCCC |
| Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
| Rating | Military |
| Technology Family | ALS |
| VCC(Max) | 5.5 В |
| VCC(Min) | 4.5 В |
| tpd @ Nom Voltage(Max) | 17 нс |
| RoHS | See ti.com |
- Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
This document introduces the advanced Schottky family of clamped TTL integrated circuits (ICs). Detailed electrical characteristics of the 'AS and 'ALS devices with table formats are provided. Guidelines for designing high-performance digital systems using the Advanced Schottky family are given along with a brief summary of the solutions to most design decisions needed to implement systems using t - Bus-Interface Devices With Output-Damping Resistors Or Reduced-Drive Outputs (Rev. A)PDF, 105 Кб, Версия: A, Файл опубликован: 1 авг 1997
Серия: SN54ALS174 (11)
- Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
