Datasheet Texas Instruments SN54AS646 — Даташит
СерияSN54AS646
Восьмеричные шинные трансиверы и регистры с выходами с 3 состояниями
Octal Bus Transceivers & Registers With 3 -State Outputs datasheet
PDF, 890 Кб, Версия: F, Файл опубликован: 1 янв 1995
5962-8759501LASNJ54AS646JT
N12
Pin2424
Package TypeJTJT
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
Width (мм)6.926.92
Length (мм)3232
Thickness (мм)4.74.7
Pitch (мм)2.542.54
Max Height (мм)5.085.08
МаркировкаSNJ54AS646JT
Parameters / Models5962-8759501LA
5962-8759501LA
SNJ54AS646JT
SNJ54AS646JT
Bits88
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Package GroupCDIPCDIP
Package Size: mm2:W x L, PKGSee datasheet (CDIP)See datasheet (CDIP)
RatingMilitaryMilitary
Schmitt TriggerNoNo
Technology FamilyASAS
VCC(Max), В5.55.5
VCC(Min), В4.54.5
RoHSSee ti.comSee ti.com
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Live Insertion
  • Introduction to Logic
Серия: SN54AS646 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Transceivers
На английском языке: Datasheet Texas Instruments SN54AS646
