Datasheet Texas Instruments SN54AS832B — Даташит
СерияSN54AS832B
Шестнадцатеричные драйверы ИЛИ с 2 входами
Hex 2-Input OR Drivers datasheet
PDF, 950 Кб, Версия: C, Файл опубликован: 1 янв 1995
5962-88523012ASNJ54AS832BFK
N12
Pin2020
Package TypeFKFK
Industry STD TermLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-N
Package QTY11
CarrierTUBETUBE
Width (мм)8.898.89
Length (мм)8.898.89
Thickness (мм)1.831.83
Pitch (мм)1.271.27
Max Height (мм)2.032.03
Маркировка88523012A
Parameters / Models5962-88523012A
5962-88523012A
SNJ54AS832BFK
SNJ54AS832BFK
Bits66
F @ Nom Voltage(Max), Mhz3535
ICC @ Nom Voltage(Max), мА0.0160.016
Тип входаTTLTTL
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output Drive (IOL/IOH)(Max), мА15/-2415/-24
Тип выходаTTLTTL
Package GroupLCCCLCCC
Package Size: mm2:W x L, PKG20LCCC: 79 mm2: 8.89 x 8.89(LCCC)20LCCC: 79 mm2: 8.89 x 8.89(LCCC)
RatingMilitaryMilitary
Schmitt TriggerNoNo
Technology FamilyASAS
VCC(Max), В5.55.5
VCC(Min), В4.54.5
tpd @ Nom Voltage(Max), нс7.57.5
RoHSSee ti.comSee ti.com
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Live Insertion
  • Introduction to Logic
Серия: SN54AS832B (2)
  • Semiconductors> Space & High Reliability> Logic Products> Gate Products
На английском языке: Datasheet Texas Instruments SN54AS832B
