Datasheet Texas Instruments SNJ54AS885FK — Даташит
СерияSN54AS885
МодельSNJ54AS885FK
8-битные компараторы амплитуд 28-LCCC от -55 до 125
8-Bit Magnitude Comparators datasheet
PDF, 287 Кб, Версия: A, Файл опубликован: 1 янв 1995
Микросхема Логический чип, Magnitude Comparator 8Bit 28Pin CLLCC Tube
SNJ54AS885FK
4 116 ₽
SNJ54AS885FK
7 458 ₽
Элитан
SNJ54AS885FK
13 576 ₽
SNJ54AS885FK
Pin28282828
Package TypeFKFKFKFK
Industry STD TermLCCCLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY1111
CarrierTUBETUBETUBETUBE
Маркировка89757013A5962-885FKSNJ54AS
Width (мм)11.4311.4311.4311.43
Length (мм)11.4311.4311.4311.43
Thickness (мм)1.831.831.831.83
Pitch (мм)1.271.271.271.27
Max Height (мм)2.032.032.032.03
Bits8
F @ Nom Voltage(Max)35 Mhz
ICC @ Nom Voltage(Max)210 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)20/-2 мА
Тип выходаTTL
Package GroupLCCC
Package Size: mm2:W x L28LCCC: 131 mm2: 11.43 x 11.43(LCCC) PKG
RatingMilitary
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)17.5 нс
RoHSSee ti.com
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Digital Comparators
На английском языке: Datasheet Texas Instruments SNJ54AS885FK
