Datasheet Texas Instruments 5962-8975701LA — Даташит
СерияSN54AS885
Модель5962-8975701LA
8-битные компараторы амплитуд 24-CDIP от -55 до 125
8-Bit Magnitude Comparators datasheet
PDF, 287 Кб, Версия: A, Файл опубликован: 1 янв 1995
Pin24
Package TypeJT
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
Width (мм)6.92
Length (мм)32
Thickness (мм)4.7
Pitch (мм)2.54
Max Height (мм)5.08
Bits8
F @ Nom Voltage(Max)35 Mhz
ICC @ Nom Voltage(Max)210 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)20/-2 мА
Тип выходаTTL
Package GroupCDIP
RatingMilitary
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)17.5 нс
RoHSSee ti.com
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Introduction to Logic
  • Live Insertion
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Digital Comparators
59628975701LA, 5962 8975701LA
На английском языке: Datasheet Texas Instruments 5962-8975701LA
