Datasheet Texas Instruments SNJ54GTL16612WD — Даташит
СерияSN54GTL16612
МодельSNJ54GTL16612WD
18-битные универсальные шинные трансиверы GTL/LVT 56-CFP от -55 до 125
18-Bit LVTTL-to-GTL/GTL+ Universal Bus Transceivers datasheet
PDF, 1.0 Мб, Версия: K, Файл опубликован: 6 авг 2001
Pin56565656
Package TypeWDWDWDWD
Industry STD TermCFPCFPCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-FR-GDFP-FR-GDFP-F
Package QTY1111
CarrierTUBETUBETUBETUBE
МаркировкаA5962-9689001QXDSNJ54GTL16612W
Width (мм)9.669.669.669.66
Length (мм)18.4218.4218.4218.42
Thickness (мм)2.482.482.482.48
Pitch (мм).635.635.635.635
Max Height (мм)3.053.053.053.05
Bits18
F @ Nom Voltage(Max)95 Mhz
ICC @ Nom Voltage(Max)120 мА
Тип входаGTL/GTL+/LVTTL
Output Drive (IOL/IOH)(Max)64 мА
Тип выходаGTL/GTL+/LVTTL
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
Schmitt TriggerNo
Technology FamilyGTL
VCC(Max)5.25 В
VCC(Min)3.15 В
tpd @ Nom Voltage(Max)6.3 нс
RoHSSee ti.com
  • GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)
    PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
    GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided.
Серия: SN54GTL16612 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Backplane Logic (GTL/TTL/BTL/ECL Transceivers/Translators)
На английском языке: Datasheet Texas Instruments SNJ54GTL16612WD
