Datasheet Texas Instruments SN54GTL16612 — Даташит
СерияSN54GTL16612
18-битные универсальные шинные трансиверы GTL/LVT
18-Bit LVTTL-to-GTL/GTL+ Universal Bus Transceivers datasheet
PDF, 1.0 Мб, Версия: K, Файл опубликован: 6 авг 2001
5962-9689001QXASNJ54GTL16612WD
N12
Pin5656
Package TypeWDWD
Industry STD TermCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-F
Package QTY11
CarrierTUBETUBE
Маркировка5962-9689001QXA
Width (мм)9.669.66
Length (мм)18.4218.42
Thickness (мм)2.482.48
Pitch (мм).635.635
Max Height (мм)3.053.05
Parameters / Models5962-9689001QXA
5962-9689001QXA
SNJ54GTL16612WD
SNJ54GTL16612WD
Bits1818
F @ Nom Voltage(Max), Mhz9595
ICC @ Nom Voltage(Max), мА120120
Тип входаGTL/GTL+/LVTTLGTL/GTL+/LVTTL
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output Drive (IOL/IOH)(Max), мА6464
Тип выходаGTL/GTL+/LVTTLGTL/GTL+/LVTTL
Package GroupCFPCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)See datasheet (CFP)
RatingMilitaryMilitary
Schmitt TriggerNoNo
Technology FamilyGTLGTL
VCC(Max), В5.255.25
VCC(Min), В3.153.15
tpd @ Nom Voltage(Max), нс6.36.3
RoHSSee ti.comSee ti.com
  • GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)
    PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
    GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided.
  • Introduction to Logic
Серия: SN54GTL16612 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Backplane Logic (GTL/TTL/BTL/ECL Transceivers/Translators)
На английском языке: Datasheet Texas Instruments SN54GTL16612
