Datasheet Texas Instruments 8408901FA — Даташит
СерияSN54HC175
Модель8408901FA
Четверные шлепанцы типа D с прозрачным 16-CFP от -55 до 125
SN54HC175, SN74HC175 datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 16 сен 2003
Pin1616
Package TypeWW
Industry STD TermCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-F
Package QTY11
CarrierTUBETUBE
МаркировкаSNJ54HC175W8408901FA
Width (мм)6.736.73
Length (мм)10.310.3
Thickness (мм)1.651.65
Pitch (мм)1.271.27
Max Height (мм)2.032.03
3-State OutputNo
Bits4
F @ Nom Voltage(Max)28 Mhz
ICC @ Nom Voltage(Max)0.08 мА
Тип входаCMOS
Output Drive (IOL/IOH)(Max)5.2/-5.2 мА
Тип выходаCMOS
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
tpd @ Nom Voltage(Max)32 нс
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments 8408901FA
