Datasheet Texas Instruments 85519012A — Даташит
СерияSN54HC259
Модель85519012A
8-битные адресные защелки 20-LCCC от -55 до 125
SN54HC259, SN74HC259 datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 15 сен 2003
Pin202020
Package TypeFKFKFK
Industry STD TermLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY111
CarrierTUBETUBETUBE
Маркировка85519012A259FKSNJ54HC
Width (мм)8.898.898.89
Length (мм)8.898.898.89
Thickness (мм)1.831.831.83
Pitch (мм)1.271.271.27
Max Height (мм)2.032.032.03
3-State OutputNo
Bits8
F @ Nom Voltage(Max)28 Mhz
ICC @ Nom Voltage(Max)0.08 мА
Тип входаCMOS
Output Drive (IOL/IOH)(Max)5.2/-5.2 мА
Тип выходаCMOS
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
tpd @ Nom Voltage(Max)28 нс
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments 85519012A
