Datasheet Texas Instruments 8415101RA — Даташит
Серия | SN54LS682 |
Модель | 8415101RA |
8-битные компараторы идентификатора/амплитуды 20-CDIP от -55 до 125
8-Bit Magnitude/Identity Comparators datasheet
PDF, 1.6 Мб, Файл опубликован: 1 мар 1988
Pin | 20 | 20 |
Package Type | J | J |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | SNJ54LS682J | 8415101RA |
Width (мм) | 6.92 | 6.92 |
Length (мм) | 24.2 | 24.2 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
Bits | 8 |
F @ Nom Voltage(Max) | 35 Mhz |
ICC @ Nom Voltage(Max) | 70 мА |
Тип входа | TTL |
Output Drive (IOL/IOH)(Max) | 24/-0.4 мА |
Тип выхода | TTL |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Technology Family | LS |
VCC(Max) | 5.25 В |
VCC(Min) | 4.85 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 30 нс |
RoHS | See ti.com |
- Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Designing with the SN54/74LS123 (Rev. A)PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
Серия: SN54LS682 (5)
- 8415101RA 8415101SA SN54LS682J SNJ54LS682J SNJ54LS682W
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Digital Comparators
