Datasheet Texas Instruments SN54LVCH244A-SP — Даташит
СерияSN54LVCH244A-SP
Восьмеричный буфер/драйвер с выходами с 3 состояниями
SN54LVCH244A, SN74LVCH244A datasheet
PDF, 1.6 Мб, Версия: O, Файл опубликован: 5 фев 2007
5962-9754201V2A5962-9754201VSA
N12
Pin2020
Package TypeFKW
Industry STD TermLCCCCFP
JEDEC CodeS-CQCC-NR-GDFP-F
Package QTY11
CarrierTUBETUBE
Маркировка5962-5962-9754201VS
Width (мм)8.896.92
Length (мм)8.8913.09
Thickness (мм)1.831.84
Pitch (мм)1.271.27
Max Height (мм)2.032.45
Parameters / Models5962-9754201V2A
5962-9754201V2A
5962-9754201VSA
5962-9754201VSA
Bits88
Тип входаTTL/CMOSTTL/CMOS
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Тип выходаLVTTLLVTTL
Package GroupLCCCCFP
Package Size: mm2:W x L, PKG20LCCC: 79 mm2: 8.89 x 8.89(LCCC)See datasheet (CFP)
RatingSpaceSpace
Schmitt TriggerNoNo
Technology FamilyLVCLVC
VCC(Max), В3.63.6
VCC(Min), В22
Voltage(Nom), В2.7,3.32.7,3.3
RoHSSee ti.comSee ti.com
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Live Insertion
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVCH244A-SP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Buffer Drivers
На английском языке: Datasheet Texas Instruments SN54LVCH244A-SP
Публикации по теме
