Datasheet ТI SN54LVCH245A-SP — Даташит
СерияSN54LVCH245A-SP
Datasheet Texas Instruments SN54LVCH245A-SP
ВОСЬМЕРИЧНЫЕ ШИННЫЕ ТРАНСИВЕРЫ С 3-СОСТОЯННЫМИ ВЫХОДАМИ
SNx4LVCH245A Octal Bus Transceivers With 3-State Outputs datasheet
PDF, 1.7 Мб, Версия: P, Файл опубликован: 6 май 2014
5962-9754301V2A5962-9754301VRA5962-9754301VSA
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетНет
N123
Pin202020
Package TypeFKJW
Industry STD TermLCCCCDIPCFP
JEDEC CodeS-CQCC-NR-GDIP-TR-GDFP-F
Package QTY1201
CarrierTUBETUBETUBE
Маркировка9754301V2A5962-9754301VRSNV54LVCH245AW
Width (мм)8.896.926.92
Length (мм)8.8924.213.09
Thickness (мм)1.834.571.84
Pitch (мм)1.272.541.27
Max Height (мм)2.035.082.45
Parameters / Models5962-9754301V2A
5962-9754301V2A
5962-9754301VRA
5962-9754301VRA
5962-9754301VSA
5962-9754301VSA
Bits888
Рабочий диапазон температур, Cот -55 до 125от -55 до 125от -55 до 125
Package GroupLCCCCDIPCFP
Package Size: mm2:W x L, PKG20LCCC: 79 mm2: 8.89 x 8.89(LCCC)See datasheet (CDIP)See datasheet (CFP)
RatingSpaceSpaceSpace
Schmitt TriggerNoNoNo
Technology FamilyLVCLVCLVC
VCC(Max), В3.63.63.6
VCC(Min), В222
RoHSSee ti.comSee ti.comSee ti.com
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Live Insertion
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVCH245A-SP (3)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Transceivers
На английском языке: Datasheet Texas Instruments SN54LVCH245A-SP
Публикации по теме
Политика конфиденциальности
