Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI SN54LVTH162244 — Даташит
СерияSN54LVTH162244
Datasheet Texas Instruments SN54LVTH162244
3.3.-V 16-битные буферы/драйверы ABT с выходами с 3 состояниями
SN54LVTH162244; SN74LVTH162244 datasheet
PDF, 939 Кб, Версия: N, Файл опубликован: 1 ноя 2006
5962-9680901QXASNJ54LVTH162244WD
N12
Pin4848
Package TypeWDWD
Industry STD TermCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-F
Package QTY11
CarrierTUBETUBE
Маркировка5962-9680901QX5962-9680901QX
Width (мм)9.669.66
Length (мм)15.8815.88
Thickness (мм)2.482.48
Pitch (мм).635.635
Max Height (мм)3.053.05
Parameters / Models5962-9680901QXA
5962-9680901QXA
SNJ54LVTH162244WD
SNJ54LVTH162244WD
Bits1616
Тип входаTTL/CMOSTTL/CMOS
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Тип выходаLVTTLLVTTL
Package GroupCFPCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)See datasheet (CFP)
RatingMilitaryMilitary
Schmitt TriggerNoNo
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
Voltage(Nom), В3.33.3
RoHSSee ti.comSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH162244 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Buffer Drivers
На английском языке: Datasheet Texas Instruments SN54LVTH162244
Политика конфиденциальности
